furz4
I am going to run green wheel bearings in my dart and am unsure if I should get the ones with the snap rings or the ones without. Would like to heat what everyone has used . Thanks.-Phil.
I know the OEM are much stronger. I do plan on doing some gear changing and testing and wanted the greens for easy swapping out centers. I don't expect them to last 40 years like the originals.
Does anyone make a rear disc brake kit where we can keep the tapered bearings and adjuster? All the kits I've seen, we need to switch to the green bearings.
Wylde1.
There are millions of GMs that will dispute that claim...lol. There is nothing wrong with Green bearings, even on road track cars. Tapered bearings are stronger in regard to side loading but they are so over engineered that most cars went 30 years without ever having them re-greased of serviced..lol. I use the ones with the clips and I get them from Cass (DrDiff). I've got them on my stuff and customer's stuff several of whom road race. There are no issues. I have only ever had to replace one side on one car because the seal let go and oil came past it. No failures in regard to the bearing themselves. It does mean the spacer in the dfferential needs to come out. But 1/2 the time they are missing or worn beyond recognition anyway.
If this is going to be a street driven car, the OE tapered bearings are a must for the side load capabilities. Green bearings are for straight line application only and offer no side load protection. Need some firsthand knowledge??? I'll put you in touch with my buddy who "was" running them in his Superbird. Was that is, until he had to change them out twice in one driving season. Or how about my buddy with the 70 Roadrunner, same thing!!! Get the tapered bearings if you're going to live on the street, Geof
back to the OP's question. one is definatley better then the other. i just forget which it is.
If sealed bearings worked so well, why did Ford go away from them and onto a tapered bearing? This is a '79 Ford Bronco 9" rear and axle, with stock tapered bearings.
Ford changed the design because the earlier Ford 9's are known for having their axles walk out of the housings under heavy load.What makes you think Ford changed the design? I have seen both types of bearings used on several different Ford rearends all throughout the yrs they made them. Why did they use both? I don't know but then again why did Ford have so many designs of each piece of their drive trains, i.e. how many 351 engine designs are their? That just seemed to be the way Ford did things. I just know I have seen alot of the sealed type used in Ford's last a real long time.
The tapered bearing design is the superior design. Will a sealed bearing work? Sure. But if the ball-type bearing fails under side load, what happens to your axle? I've seen more than one fender trashed when a green bearing let go.I have also seen tapered types walk out. All the ones I saw were caused by the retainer letting go. Brian I don't claim to know everything but I do know I have seen alot, and I mean alot of Ford rearends and only a few had bearing problems.
The stockers take a couple minutes extra to adjust. They last just about forever, and they cost about the same as a green bearing set. Why change them to an inferior design, even if it does work for most people?I do agree the tapered type is superior. See my previous post and read it again and you'll note I never said sealed bearings were superior. But does that mean sealed types are junk? I don't think so, but that's my opinion from my 30 yrs. of experience of working on cars professionally.
