demon seed
The Original Demon Seed
Is it any wonder why I kept my reply to the original question "short and sweet".:-D:-D
Why are you guys so down on the OE tapered bearings,
I am going to use the newer design with snap rings. I suspect the reason some might have problems is the press operator that installed the bearings. Was helping a friend today work on a front wheel bearing on a lumina that was replaced less then 6 months ago and is bad again. We'll be cleaning up the spindle and pressing the next one ourselves. A 60 ton press will make anything started crooked go right on. I have a hard time beleving a green could fail bad enough to push through an 1/8 steel retainer plate. I look at this as am apples and oranges comparison. Tapered is pretty much a lifetime bearing even if you abuse it, while the green is more like a front wheel drive where you know at some point you will be changing it.
Oh and I've known some lifelong mechanics that are still hacks and butchers. Just because you've been doing it a long time doesn't mean you've been doing right.
Not saying that anyone mentioned in this thread is a hack, I'm just sayin'...
I don't remember what we torqued it to. Did look it up and it was torqued to spec.
i beleive its yukon or somebody recomends not to use green bearings on there axles at all!
and cool info about having to use the greens with a spool!
i am working on building a 8.75 3.91 posi for my 68 dart SL6 and i went with the tapered bearings.
My car will get driven so we'll find out soon enough how they do
