Got the engine bay cleaned up!Tightened up the trans pan bolts.
Yes sirLooks great! Any idea if they make them for early A's?
ThanksThat is one damn NICE car!
replied to your general postWhat length bake hoses you guys running with your gerst setup?
tti with a short deck right side went right in from the bottomain and I had to raise the engine a little to clear the steering shaft.Then I hooked it to the rackIf you can make that pan work for you then BONUS .... since i did not order pan i will go with pan recommended by Carl to clear rack ... How did the headers fit ?... which ones did you have ?...
240.No porting.I' going to try this Performer Rpm.If it don' work out I'm going trick flow.Im going to try and keep my engine max Rpm at 6500.I' going to touch up my oil pan it got scratched up when I put the engine in!AWSOME....im also using trickflows... which ones did you get 240/270's? and what intake .. thanks
