hard brake pedal cant get back brakes to bleed.
Looks like the proportion valve is the problem,i sprayed brake cleaner to one the rear line ports hole and nothing came out on the other side of the port hole.looks clogged or jammed up.
Is the portioning valve from inline tube a good valve for being reproduction?i ended up orderin one
