my68barracuda
working with an a 833 OD, that I had the shifter and tranny rebuit by Brewers.
I probably have less than 200 miles on the tranny since the rebuild(s), and there is no gear grinding..
shifting into 1st, 3rd and 4th there is a 'click or notch' that the shifter falls into,shifts real nice, however when pulling back into second gear, the shifter feels like it locks, then I need to give it a hard pull to get it into 2nd gear,, this is on second only.No gear grinding,, just feels like the shifter gets stuck..
I have lubed it, sprayed the plates and linkage with kroil,,,
I set the linkage up using the 1/4 inch or what is specified dowel, made sure it progressed all the way through the shifter,,
any ideas?
thanks
any ideas?
thanks
