ive got a 1973 plymouth valiant 318 auto with 2bbl carb. runs great but after you shut it off it doesnt want to crank. starts fine when cold. have replaced all ignition lowered float im stumped:sign10:
temp related failure can be a loose connection at the battery, the coil, the ignition module, pick up coil in dist., You need to verify whats missing when it fails to start, spark or fuel. Good luck
