[SOLD] Harland sharp 1.6 rockers sb
trbodrt
so. cal
Harland sharp s70026k shaft mounted 1.6 rockers for sale. These are brand new and in perfect condition, only used for mock-up. Includes 16 adjuster and nuts and billet steel hold downs and hardware. Asking $600 plus shipping.
Cheapest I've seen these rockers new is $630 plus tax and an additional $90 for the billet hold downs.
They are the shafts that came with the rockers from harland sharp. Looking at the website it says they are heat treated. I'm having a geometry issue with my indy rhs heads, I guess it's pretty common for these heads.
When checking the sweep of the rocker tip on the valve stem it's off to the exhaust side when I would like it to be more centered.
Not to add any commentary to a sale thread, but it may help the OP or a buyer to know, that the hold downs, and spacers can be swapped or modified to re-center the rockers on heads with offset valves. May want to contact randy jr at harland sharp. Hope that helps.
