[SOLD] Harland Sharp Roller Rockers 1.7 Pedestal Mount
thomasfouraker
Jacksonville
S70037 Harland Sharp Roller rockers for magnum heads.
These are new, not used but were mocked up. My build changed directions and required a new camshaft that needed 1.6 rockers.
About half did develop minor surface rust on a portion of the roller. I suspect because I left them out in my humid garage for some time. I contacted Randy at Harland and he said he would replace each roller for $4 if I wanted them replaced, but said some scotch brite and WD40 would clean them up.
Will try and attach pictures, in the meantime if you need some message me your number and I will text them to you.
$225 shipped.
I was able to find 8 that had some form of defect on the roller. The rollers feel smooth and I wouldn’t hesitate running them as they are after looking them over really well. Might would get some 3000 to polish it a bit before hand.
Tried to capture the best I could.
The pedestal and fasteners are in a bag not pictures. I have kept these bagged up in pairs, drenched in oil and stored climate controlled since I decided not to use them.
Thanks!
