Harmonic balancer help
Found this one on ebay from Racers Outlet. $75 plus $15 to ship FWIW..
Part Number
BrandBalance
Style
Outside
Diameter
RPM
Rating
Weight
lbs.
80012Professional ProductsInt/Ext7.3"65008.12
This item is a brand new PowerForce series harmonic balancer made by Professional Products. It is suitable for high performance street applications and mild (non SFI) racing applications to 6500 RPM.
It fits small block Chrysler 273, 318, 340 and 360 V8 engines.
This damper is supplied as a neutral balance damper and comes with three bolt-in counterweights. This allows this one part number to fit four different small block Mopar engines. The damper without any weight fits internally balanced 1967 and later 318 V8's standard and Magnum, and all internally balanced 273 and 340 engines with forged cranks. One weight is for 340 externally balanced 1972-’73 engines with a cast crank. A different weight is for 360 externally balanced 1993-’97 engines with a cast crank. And the third weight is for 360 externally balanced 1971-’92 engines with a cast crank. Each counterweight is numbered, and the instructions guide you which weight to use for each style of engine.
For more information you can go to Professional Products Harmonic Dampener Instruction Booklet
PowerForce Damper Features:
  • Precision machined from nodular iron - over 30% stronger than stock
  • Outer ring and hub are bonded together to prevent slippage
  • Accurate crank bore for proper press fit to crankshaft
  • Externally balanced dampers feature bolt-in counterweights except #80001
  • Gloss black finish with 60° of bright white timing marks plus marks at every 90°
  • RPM Rating: to 6500 RPM
