What are your plans for the 360 ? If its a street rod type build, I would think the stock balancer is fine as long as the rubber ring is still pliable.
I don't have experience with aftermarket balancers so I cant comment about them. If I were going to replace one, I'd use one of those silicone fluid balancers, from what I can tell they are pretty nice pieces, but I also seem to remember there is a problem with pulley alignment when using these. Whatever you do be sure to get the rotating assembly balanced when at the machine shop including the weights for the torque converter.
Good luck with it !
