threewood
I thought my car was haunted. My timing would change randomly. Finally came to a head last night. Previous night I installed a collar on my distributor shaft to keep the gear from coming up. Timed it to 20* initial / 35* total, vacuum unhooked. Adjusted the carb and all was well. Yesterday I wanted to up the idle a bit, and double check the timing. WTF!!!!
Timing mark nowhere to be found. Idle was smooth and the drill holes in the balancer were steady as a rock, reved it up and ran the advanced light up past 50*, no tdc mark. Switched timing lights and same thing.
Found TDC this morning.... F$%#! Two red dots are cw and ccw marks from the piston stop. Red slash is TDC.
So, my question is...what harmonic balancer do you recommend for a street driven 1962 318 Poly that rarely sees over 5500rpm? I looked around and don't think I need a $400 job. What is a good one for forged crank, pass side timing tab? Looks to be 7" diameter with a rough measure.
Thanks!
Thanks!
