kork340
Hi all, I'm putting a 68 318 in my 72 Duster. I changed timing cover and water pump so they work for my radiator. My question is on the harmonic balancer.
The one that matches my new timing cover looks like a cast crank balancer, and the old one looks like a forged crank balancer, going by the pics in How to HotRod Small Block Mopars. Does it matter, as long as my pulleys line up? Or do I need one for a forged crank? Also I read a post where it was said that when the dots on the timing gear are at 6 and 12 that #6 cylinder is at TDC, not #1, but with mine set up there, #1 is up at TDC and the timing mark on the harmonic balancer is at 0 on the timing cover. Is this right? This is the first 318 I've ever rebuilt. I never had to rotate the crank around from when I installed the timing set, like the other post stated. Am I in right?
Thanks.
Thanks.
