Has anyone reversed the twin hood scoops for a cowl induction effect?
BullyDodge
winnipeg, manitoba
In the process of rebuilding my 68' Dart. Came with the dual hood scoops. Would like to install a hood tach on like some of the Plymouth Road Runners which got me thinking about reversing the twin hood scoops All three then from the front, in same color, would appear as bumps on the hood with facings toward the driver. Less of a distraction in appearance perhaps. From other pictures it appears the scoop opening, if you could use the same holes (or modify), it appears it would be close enough to the windshield to gain the cowl induction affect. Any thoughts??
The Dart Scoops are long and skinny by effect.
Maybe the Dodge Daytona fender scoops would give a better look and action for your reversed effect on the Dart Hood.
might give better ground affects... air coming into the engine bay through the front creates lift at speeds.
Hood openings with negative air pressure would allow the air and heat in the engine bay to escape through the rear facing scoops... maybe?
Help keep the front end from floating at high speed and let heat out. just a thought...
The only benefit would be to you personally if you like that look, not the engine. Most cowl induction hoods have the air inlet in the center of the hood feasting off of the air from that part of the windshield.
Yeah, to get any benefit from cowl induction the opening needs to be very close to the base of the windshield — the high pressure area is right at the angle. Anywhere on the flat hood is laminar flow.
Those 70 scoops look terrible on a 68 dart anyway in my opinion, turning them around backwards is just gonna look exponentially worse.
I'm saying it would look wrong, about like the young kid in my high school that put chrome traction bars on his nice 66 Mustang BACKWARDS-he was the laughing stock in high school. So in other words, you'll probably get called a dumbass a few times.:rofl:
Take fresh air from the cowl chamber. I'm on my phone now so I am not going to look for it, but there's a guy here who was taking fresh air from there on his car.
The ducting looks ugly as ****, but if it's stupid and it works, it ain't really all that stupid.
Something like one of these?
If you're talking about those shorty scoops like on the Formula-Ss; I was 16 in 1969, and even as a dumb kid in high-school, I could tell those were tacky; and the hood-tach was even tackier.
As to scoops in general, the thing is, on an automatic street car, 65mph will get you ~4200 or so in Second gear with 3.23s, and yur engine is barely getting up on the cam. A few extra hp from even a good scoop will do what?
at 65, you just don't have enough roadspeed yet.
