Montclaire
Hello, I know this is an A-body board, but this seems to be THE place for 5.7 swap info, so I figured I would join and ask a few questions. I have looked through several posts on here, so really I'm just trying to put everything together in my head and seek a little guidance.
Let me say that I am not looking to upgrade the motor, the K-frame, or the chassis beyond any factory variation. The point is to get the reliability of fuel injection and 50-state parts availability on the motor. I will be using a small block 727, and would like an in-tank fuel pump. Brakes will be manual but I would like to keep the power steering; the later Bs should have some more room in the engine bay so I don't think it will be a clearance issue.
I know I can get spool motor mounts, so that's good to go. For the motor itself I'm looking for an early truck hemi as that will mate up with a cross flow radiator similar to several mid 70s chrysler offerings. I want to keep a clutch fan instead of electric, I did see this done in a magazine article, so that's a go as well. I'd like to use a factory looking airbox, maybe one off a jeep wrangler or similar, mounted where the battery would be (I'll relocate to the trunk).
For exhaust I am looking at the Jeep (non-srt) mainfolds which I can only guess will clear. I do not want to buy headers. If they are cheap and work that is fine with me. Is anyone selling H-pipes with an O2 bung to mount up to these in an older mopar? There are several choices for oil pans, so that's no problem, and I know of the 45' offset adapter for the filter (or just use a hockey puck type?). From what I have seen I can use an eliminator pulley to get rid of the AC compressor and a power steering kit to adapt the pump for the older box.
Now the fun part, wiring. I have seen the S&P harness, are there other options out there that would work just as well but save me a couple bucks? $1300 for a harness seems way high. I believe that I still need a factory computer with that, does it have to be for a manual? Also, from what I understand, I can use either the early or later drive-by-wire pedal setup, but it's only the earlier one that will give me the cowl switch unit which will allow me to use a trans kickdown. What about the alternator, is the output too high? Do I need to regulate it some how, or will it use the stock 73 regulator already in the car? What about my dash gauges? How much splicing do I have to do to connect up to my factory ignition, charging, and power leads?
What are my options for a fuel tank? Does anyone offer repop tanks with a built in pump or modified sending units? I have seen the corvette filter piece that S&P offers so that you do not have to plumb a return line. I know for the trans I need a special flex plate and a non-weighted converter. What application would I be looking at for a non-weighted converter with a stall speed suitable for a mid 70s b-body?
What did I miss? Thanks
