Michael Nelson
1974 Dart Sport 360 4 speed
I'm new and a few weeks back bought a 1974 dodge dart sport 360 4 speed. The electrical worked but was kinda janky. I pulled the dash harness out and cleaned it up. Made sure I didn't screw any of the wiring up. But maybe I did, now I don't have brake lights or hazards. When I used my multi-meter the pink wire at the kick panel creates a loop with the black green and brown wire when the brake is pushed, but the wires for the tail lights are purple a different part of the connector. Hazards only work when the turn signal is engaged. I know there are two of those flasher units, the one next to the dash cluster doesn't go off, but the actual flasher is good. There are a few single connectors that are unplugged but I believe everything is wired up right.
