xring Well-Known Member Joined Jun 1, 2009 Messages 100 Reaction score 2 Location WV Jul 30, 2009 #1 Is there any big disadvantage to using head studs on a small block? Can you get the heads on/off with the engine in the car? Say, 70-72 Duster with no power brakes? Thanks!
D dstdevl bruce t johnson Joined Jul 30, 2009 Messages 44 Reaction score 0 Location Wadena Minnesota Jul 30, 2009 #2 I find the studs better then regular bolts. I think you get a better clamping load.(esp if you plan to use NOS) Also if you have freshly bored cylinders you'll have less distortion in the cyl walls. BT
stroked 340 Banned Joined Oct 10, 2008 Messages 3,117 Reaction score 23 Jul 30, 2009 #3 I run ARP head studs on my small block '70 duster and need to remove a few of the studs to get the heads off...
