Yep. Changed the whole torque curve (moved it down in RPM and the peak was probably higher) and it just worked out to be better with the car weight, drivetrain setup, etc. It is like what we talk about with cams and 'more area under the curve', only here it was 'more total energy under the curve'.
So what is that, that I keep hearing about flow trumping compression every time? LOL
Flow does trump compression IF you have enough compression and IF you’re not killing flow to get the compression.
As an example (this is exactly what happened) I took on a set of BBC heads. I flowed them as they came in, after the valve job and then after porting so I had all the numbers.
The owner claimed 14.5:1 CR, but all I had was the heads, so I couldn’t verify if he knew what it exactly was or not, but that’s what he said.
Both valves were extremely shrouded by the chamber. So I unshrouded them first, then I made some changes to the shape of the chamber, because it wasn’t what I like. In fact, I did what is called “softening” of the chamber, even though it was an N/A deal.
The up shot is, by the time the work was done, he was at 13.9:1 compression, but his flow numbers were up. A bunch. Plus I got about 6% lower reverse flow numbers, so that was a bonus. The customer was livid he lost that much compression. I told him the flow gain was much more important.
Fortunately for me, it was going back on the dyno where the engine was done in the first place. It picked up power on the dyno, but the shop said it won’t matter...in the car it will not show an ET reduction because of .6 less CR.
Unfortunately for that shop, the dyno numbers and the new ET matched exactly what they should have been.
So yes, airflow does trump compression, if you are losing airflow to gain compression.
Another example is my junk, and FABO member Zigs builds. I stick the piston out of the hole so I can reduce the dome. I didn’t actually give up CR, but I made compression the correct way, less dome, more CR.
Zigs’ is the same way. I milled down his dimes but stuck the pistons out...how much I don’t remember, but if he doesn’t care I’ll post it up when we put it together. But he will be a measure 10.25:1 when it goes together. Should be a real neat engine for his car.
