Head gasket?
tekslk
McClure, Pa
I will be putting eddy alluminum 60779 on my car in about 2 weeks can anybody recommend a good gasket, and should I use a bolt kit or studs? Part number please. Street driver. 360 with 10-1 compression.
FelPro 1008 is what Eddy recommends for their heads.
Im ok with them I have a rpm air gap intake what do we recommend there also?
If the pistons are out of the hole that .039 gasket won't work. Something to check into so the pistons don't smack your new heads. Bolts will work fine.
