E Enjoying it again Well-Known Member Joined Apr 28, 2019 Messages 107 Reaction score 67 Location Ontario Apr 25, 2022 #1 Where can one find new headlamp and turn signal pigtails for a 72 Dart. Please and thank you.
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,297 Location Idaho Apr 25, 2022 #2 Headlamps "were" standard for everything, NAPA or most any other parts store. Socket pigtails you may need to take one apart to get a sample. The "key" on the insulator must match
George Jets 1967 Dart 2 Door FABO Gold Member Joined Jan 18, 2019 Messages 9,922 Reaction score 14,362 Location Farmington MN Apr 25, 2022 #3 Yep right at your local Lowes home improvement center in the trailer hitch / trailer wiring area of the store. If not in stock, sure they can order them in for you. Just picked this one up last week here at Lowe's to use with Mopar Turn Signals and Distributor wiring plug in connectors. Around 5.00 bucks if I remember correctly.
George Jets 1967 Dart 2 Door FABO Gold Member Joined Jan 18, 2019 Messages 9,922 Reaction score 14,362 Location Farmington MN Apr 25, 2022 #4 If you are in a quick pinch you can cut a Flat Four trailer plug in half and that will make the connection for you too.
George Jets 1967 Dart 2 Door FABO Gold Member Joined Jan 18, 2019 Messages 9,922 Reaction score 14,362 Location Farmington MN Apr 25, 2022 #5 I see the Hopkins 47965 Pigtails are quite plentiful on e-bay too. Just type: Hopkins 47965 into the ebay search window.
