[Found!] Head Pipes
You would have to specify a 70-71 Duster 340 Classic Industries, AccurateLTD, Gardner Exhaust...
OK I will give them a call tomorrow..Thanks
Your local muffler shop can make some I bet.
Absolutely! For most my cars, I usually take a framing square, a tape, and a speed square, write down the numbers, and roll. DISCLAIMER: great for headers back...I would not try to do the over axle and out that way. Jes sayin!. However, if'n I pull my head out my ***, I may take the 2" rears up off my car n take em up and have em duplicated in 2.5".
The drivers side necks down to go past the torsion bar. I think it’s 2 inch there, then as soon as it’s under the car it’s 2 1/4 to the muffler. The passenger side is 2 1/4 right off the manifold I believe. I can measure them next time I’m out at my storage. Kim
Thanks Send me a PM with the Info.
I have two sets from a 70 Duster. One set new and one set slightly used. Slightly used set is $75 plus shipping. I also have the tail pipes for tips. $20 each used tips for them ad $85. Complete exhaust minus mufflers $200.
Complete new sticker exhaust with mufflers $500 plus ride.
PM sent
I sold the complete Exhaust. You only wanted the front pipes and another member bought the whole new exhaust. Front pipes , mufflers, hangers, tailpipes, tips and tip hangers. I only have the used set left and need to keep one of the exhausts for a car that is here.
OK Thanks for the update.
I can bend them would be 2’’ OD. I think i have the card for 340. I bend all my big block darts.
One more time the front pipes are NOT 1 7/8. Drivers side is 2 inch then goes to 2 1/4. The passenger side is 2 1/4 right off the manifold. Get the pipes from oldmanmopar. He still has the used set. Kim. Pics. First 2 are the drivers side with the indent for the torsion bar, then to show the 2 1/4 over the 2 in pipe. Then the middle pipe is the pass side showing 2 1/4 right off the flange all the way to the muffler.
The drivers side is 2 inch for about 18 inches. I would have to measure. Then 2 1/4 to the muffler. Idk how he got 1 7/8s. Pass side is 2 1/4 all the way. Here is a pic of the drivers side. The pipe is flattened some to go past the T bar. Then 2 1/4 after that. The pipes are also flattened on the bottom in a couple of places. Pass pipe pic in the middle. Other pipe is 71 up Walker brand. Kim
Hi,
Contact Dons exhaust Canton Ohio. He has what you want. Google it.
I have TTI and Accurate head pipes available (I would separate the Accurate) but they are 318 ball and socket not 340 flange.
