header on a 63-64 dart
moparraceman
mansfield ohio
all these guys putting 340-360 engines in early darts 63-64 and running under chassie headers. what header are they using ? pictures,part numder ,and brand of header would ne help full thanks
AFAIK, only to fit manual steering with a 904. 727s are too wide and need the collectors altered/spread, 883s may run into clutch linkage interference and need mods.
Hedman makes a set of shorties for later As that will fit early As if you modify the #1 tube and collector- this also allows use of power steering. There's a thread covering the mods on here somewhere...
Hedman Husler will make you their fenderwell race headers...
We had Schumacher, but I am afraid he is done.
I have TTI in my 63 valiant with stroked 360. Not sure if valiant and dart have same header space issues. They are still a tight fit. Torsion bar runs through one of them. No power steering or power brakes but do have mini starter.
Which hedman headers are you talking about?
The shorties for "67 & up.. I BELIEVE #78500.
There was a nice writeup about rerouting the #1 tube to merge with #5 and trimming the collector at the old #1- this not only let them fit the early As, but let it fit power steering, too. Pass side is a drop in.
Thought I had it bookmarked, but can't find the thread now. Search turned up references to it, but not the original thread. I'll post the link if I can hunt it down.
Not the one I was thinking of, but this thread may help.Removing stock exhaust manifolds
Couple of pics from the thread:
