They can be made to fit, but like I said, you have to be willing/able to do fab work to modify them. Remember, these are designed for later ('67 and up) A bodies, the early As are quite a bit more confined.
The passenger side fits fine, however the driver's side needs a bit of work.
Stock:
Modified:
Note that the #1 tube has to be cut and rerouted so it joins the #3 tube, and the collector needs to be reworked after #1 has been removed from it. Since #1 and #3 don't fire at the same time, sharing the #3 exhaust tube has minimal effect on the performance of the shorty header.
63 dart v8 swap
Somewhere on here there’s a thread that shows the head pipe on the drivers side, even on the 67+ cars the corner you have to make from those Hedman’s to get around the center link is ridiculous.
