Yeah, those are badass for sure! Geez, they cost 3x what I paid for the whole car! lol
I looked in to the stainless headers , they told me they don't make them to fit a W2 /Indy head bolt pattern and he wasn't sure if a 90 degree oil filter adapter is needed when using their header
Beautiful! That’s the same color I’m painting my car too!John is right, they are a pain in the butt to put together after having them coated, but I'd do it again. Mine fit great with the exception of the Milodon pan.
Sounds like you're building a nice engine, I'd go with a bigger carb though.
I have hedmans on mine. They will step them up to 2.125. I would give them a call if you don't want limited to 1.625 or 1.750
What size front tire and wheel are you guys running with these Headman headers? Backspace and width of front wheel if known as well please?I also run the herdman's. They fit well into my 73 duster with a stock front suspension. One tube on each side goes through the inner fender but as long as you don't have a problem cutting the hole, tire clearance is not an issue. I did have to beat the one tube in to clear a 8qt milidon oil pan and the just a little to give more clearance around the oil filter. I ran them for 2 seasons with just paint on them but pulled them over the winter to have the ceramic coated. I'm very happy with them.
I usually detest fenderwall headers due to how hacked it makes things look.. but those are damn nice and a beautiful installJohn is right, they are a pain in the butt to put together after having them coated, but I'd do it again. Mine fit great with the exception of the Milodon pan.
I think mine are 15 X 3 1/2" with a 1 3/4" BS, the tires are 26" tall M/T radials. On my Dart the tire will hit the fender before it even gets close to the header.What size front tire and wheel are you guys running with these Headman headers? Backspace and width of front wheel if known as well please?
Thanks, as you can see I missed the hole on the passenger's side, didn't allow enough drop for the bend in the tube. I'll center up the next one. LOLI usually detest fenderwall headers due to how hacked it makes things look.. but those are damn nice and a beautiful install
Nope, what i see there is access clearance to get the pipe through easily and a socket for the rear boltThanks, as you can see I missed the hole on the passenger's side, didn't allow enough drop for the bend in the tube. I'll center up the next one. LOL
Ordered one of them fancy ones you recommended. Like I told you the other day John, I can’t afford to be your friend. That and my wife said I can’t play with you anymore! lolI advised him yesterday about the Milidon oil pan issue but like I told him that company is dead to me. If you can’t fix an issue after someone discusses the issue with you for a month and sends you 20 pictures you my friend are an idiot. Their pans now suck and are unusable as delivered.
7 quart.Which pan did you go with. They do offer some nice ones.
Just curious, what brand? Canton? I was looking at kevco cause.. cheap and they look decentish..7 quart.
KevcoJust curious, what brand? Canton? I was looking at kevco cause.. cheap and they look decentish..
oh nice... i was expecting it to be some $800 canton gold plated super pan I was looking at the kevco "Cheater" pan.. looks stock but has baffles and holds 1 more quart
i just have skinnies on mine. but they are 28 tall. pretty sure i have tons of room.What size front tire and wheel are you guys running with these Headman headers? Backspace and width of front wheel if known as well please?
[SOLD] - Mopar 340 race headers, New NOS Tubular Automotive, A bodyTubular Automotive TDR8 1-7/8. All tubes exit chassis. No tubes go thru federwell
Probably don’t have them on the shelf.
They make sub flanges for J and W2 heads
A previous post with pictures. Looks like Milodon 7 qt street strip oil pan clears with plenty of room.
