423dak
- Joined
- Jun 16, 2009
- Messages
- 110
- Reaction score
- 3
Went to install my a-body headers on my Magnum engine today but the header pipe is hitting the block. The header is a long way from the head because of it. It is hitting casting for the upper mount bolt for a Dakota or 1/2 ton on the left side. Has anyone seen this? Did you dent the pipe? Which I'd rather not. Or grind the casting off? I was worried it may hurt the block if I grind it, but the appears to be plenty to grind off.
