Don't get this doom and gloom, if he can't go headers ain't the end of the world just has a little less power.
And always can do a swap down road, sometimes and probably a lot of times people have to run a compromised combos. The only option ain't all or nothing.
@273 said you could do the logs now and upgrade to good headers later. That is good advice IF the B body logs will fit in an A body, and I am not so sure they will. Evidently, @Carnut68 is not sure if they will fit either. That is why the A body big block logs have different part numbers than B body logs. You need to find out whether they will fit or not before making a decision. Please do not even consider using the fenderwell headers.
If the B body logs fit, I would go that route for now with the intent to upgrade later.
I weighed everyone's advice and thought about the power I'd lose and decided to buy some B-Body headers and do the minimum necessary clearancing. Much as I'd like to buy some TTI's, it's just not going to happen. That being said, any specific brands or P/Ns to buy or avoid?Maybe, I've never tried it. I have seen guys use C body HP manifolds and angle mill them. Not exactly an easy solution but I've heard that it works. On my Duster I just used the smallest header I could find and that seemed to work okay but it was only 600 hp.
Engine Master did a dyno on headers before and after beating on them pretending to make them fit and loss very little hp, by the end them beat them up pretty good.I weighed everyone's advice and thought about the power I'd lose and decided to buy some B-Body headers and do the minimum necessary clearancing. Much as I'd like to buy some TTI's, it's just not going to happen. That being said, any specific brands or P/Ns to buy or avoid?
I saw that same episode, which is part of the reason I'm not going to feel bad about "massaging" them.Engine Master did a dyno on headers before and after beating on them pretending to make them fit and loss very little hp, by the end them beat them up pretty good.
What kind of massaging of parts did you have to do? What motor mounts? It's tight, but they work.B Body manifolds fit fine. Mild 440 ran mid 12s with them! Not to mention crap 516 heads.
The Hedman 78030 fits nicely with a few minor dings . manual steering and a mini starter is needed.I weighed everyone's advice and thought about the power I'd lose and decided to buy some B-Body headers and do the minimum necessary clearancing. Much as I'd like to buy some TTI's, it's just not going to happen. That being said, any specific brands or P/Ns to buy or avoid?
Yeah, you can find someone on here saying most anything. Back in the days when I was making engine dollies I had a guy on the forum tell me that he didn't need to buy an engine dolly since he just went to the grocery store and stole a shopping cart when he needed a dolly. So that is the level of advice you sometimes get on the internet.I’ve read numerous post while searching this site that said B-Body headers would work in a big block A-Body with clearancing.
I know that guy,......Yeah, you can find someone on here saying most anything. Back in the days when I was making engine dollies I had a guy on the forum tell me that he didn't need to buy an engine dolly since he just went to the grocery store and stole a shopping cart when he needed a dolly. So that is the level of advice you sometimes get on the internet.
