bbeep71
I'm going to use relays for my headlights. The factory harness uses a wire that goes from left to right headlight(series) to the radiator support. How should I ground the headlights using the relay setup. I'm using 12awg wire to connect to the headlights. The car is a 66 Cuda with 2 lights.
Thanks
Thanks
