tampacuda69
I installed the relays from Rob"crackedback". They are in my '69 Barracuda notch. A 60 amp. Denso alt. is in service with the output wire running to the starter relay. I added a dedicated 12ga. wire from the battery ground terminal to both sides of the radiator support where the lights pick up their ground. The results are amazing. Take note of the dash light intensity.
The photos were taken on the same road, while stopped in neutral, at the same spot.
The headlights are 21 year old Sylvania halogens in all photos.
Before it is mentioned or asked let me say,
1. My '69 notch has a '67 hood and grill with '68 inserts. That's the way I bought it 22 years ago and I like it.
2. I will be adjusting the headlights but didn't want to change anything for the photos.
3. The factory tach works but is too small for me to see clearly.
4. In images 705 and 707 I don't know what those 4 brown animals on the left side of the
road might be. I didn't notice them until I reviewed these photos.
Rob's relay kit was easy to install and you can see the results for yourself.
