At the A-body headlight store....If so where can i get one?
Yup!! GE's H6024NH is probably the best sealed beam you can buy new these days.At the A-body headlight store....
Seriously though - https://www.amazon.com/dp/B000H29WN2?tag=viglink21494-20
I would probably replace the pair. If you want to make a big improvement, put in relays if not already done.
Make sure you are getting power to that side. The normal OEM run is usually, power to the driver side light and then a jump wire from that connector over to the pass side. Check the pass side connector with a volt meter or test light.
Otherwise the suggestion that ZKX & Mattax made on the GE light is great. I suggest that bulb for single headlight cars all the time when installing my relay kits. Make things very bright!
hey we all started somewhere. Most of us that was knowing little to nothing, whether we knew it or not.Another unbelievable !----------the op !
