BillGrissom
Posting for posterity since I found little info on the headliner bows. Hope it helps others.
Apparently 2 and 4 door are same and 1964 & 65 same, but Darts have 6 bows and Valiants 5 bows. I marked my bows when removed. No assurance a P.O. didn't swap them, but the remnants appeared OE headliner. Another post stated same color markings as mine (65 Dart Headliner bows. WTF?). I also couldn't find a better order which fit the car. Lengths are straight across from tip - tip (not along curve), relaxed on the bench.
Front, Length, Color(s)
1, 48.0" , brown (bit orangeish)
2, 48-1/2", orange
3, 48-5/8", blue
4, 49-5/8", pink
5, 50-3/8", none
6, 48-1/4", red & blk
Rear
#6 has two spring clips which secure it in tension to the rear valance (convoluted end slides into hole to detent) and has 2 round 90 deg "shoes" which fit into round holes in the side of inner C-pillar. You can buy new spring clips (pricey), but not shoes.
Most Curved to Flattest: 5, 6, 4, 3, 2, 1
One is very tight against the roof (#4 recall) and one loose (#3 recall), but swapping them makes even worse.
2, 48-1/2", orange
3, 48-5/8", blue
4, 49-5/8", pink
5, 50-3/8", none
Rear
