siuauto
Putting together a small block stroker motor. I need to purchase fasteners for the heads. Going APR but curious if I should go studs or bolts. Is there any disadvantage to going with studs?
It’s not a blanket statement obviously (I should have been clearerI use studs on everything but it’s not for placebo. I do it because I want the screw load up at the nut and not in the threads in the block.
"the screw load up at the nut and not in the threads in the block."I use studs on everything but it’s not for placebo. I do it because I want the screw load up at the nut and not in the threads in the block.
It just does not work that way, the load applied is going to be distributed equally across the length of the bolt shaft from the under head down to the threads whether using bolts or studs.
Think of a bolt as a rubber band, as the bolt is tightened it stretches along its shank. The pulling of the shaft longer provides the tension to make the clamp load that keeps the cylinder head compressed.
In comparing bolts and studs, think of a rubber band being stretched and twisted at the same time, that is how clamp load is developed in a head bolt. Now think of a rubber band being stretched as it is held so the lengths of the band are held parallel to each other. That is how clamp load is developed in a head stud.
The single action of only pulling and not twisting is easier on the bolt shaft, and develops a more repeatable clamp load when torque is applied.
Remember the head gasket that you are trying to keep in place never sees the torque that is applied to the head bolts or studs. The head gasket sees the clamp load that is generated by the stretch of the head bolt or stud that occurs when sufficient torque is applied. The more repeatable the stretch, the more repeatable the clamp load.
Good post and advice. I have that book.Serious hardcore racing? High CR? use studs. Otherwise it’s just blowing money on unnecessary overkill and a placebo effect. Everything else bolts are more than adequate. ARP bolts with washers and using the lube as they advise correctly and then Tighten them in 10 ft/lb increments. Learned this 35 plus years ago from the 40+ year old Mopar Bible. Nothings changed as far as tightening head bolts correctly.
Street motor or ??Putting together a small block stroker motor. I need to purchase fasteners for the heads. Going APR but curious if I should go studs or bolts. Is there any disadvantage to going with studs?
yeah, mostly street but very hot street. It will see some track time.Street motor or ??
I think its better insurance.I don't know if I need them at 11.8 cr but I'm going with studs, I was advised
I went with studs on a 11.4-1 - 360 engine.I don't know if I need them at 11.8 cr but I'm going with studs, I was advised
That's the good stuff!I went with studs on a 11.4-1 - 360 engine.
Cometic gaskets got the nod for use.
I've always reused the original head bolts.Putting together a small block stroker motor. I need to purchase fasteners for the heads. Going APR but curious if I should go studs or bolts. Is there any disadvantage to going with studs?
Cometic here as wellI went with studs on a 11.4-1 - 360 engine.
What compression ratio ? Sbm are notorious for gasket issues at high ratios because of using only four bolts per cylinder.I've always reused the original head bolts.
I save my money for rod bolts and main studs. Never blown a head gasket, ever.
After 2 builds on same heads, they checked flat within .001
Thats over an 8 year period.
Once you have your stuff milled flat, its good unless you overheat the heck outta it or need them smaller.
One thing that can be nice is the smaller 12 heads.
To your direct question...
bolts are my recommendation.
True, but that's usually up around 12.5 or more with an edgy tune.What compression ratio ? Sbm are notorious for gasket issues at high ratios because of using only four bolts per cylinder.
