Heads up on Factory Mani's with Edlebrock Heads
CUDACOX
Innisfil, Ontario, Canada
I don't know if anyone has had this experience but,If you are using Edlebrock heads with 68-70 340 Mani's make sure you use extra gaskets between the head and mani on the drivers side. The mani touches the block and can't be tightened enough without thick gaskets! Beware!!
