69 Barracuda vert
Active Member
I bought their ignition box (HRR688) and the Pertronix coil together and a distributor from HallifaxHops and the harness from YearOne. I started the car and it ran wonderful long enough for me to time the engine and then it shut off and would not start again. I checked the coil and I had spark and fuel just would not start. I had deleted the ballast resistor so that was not the issue so, I called FBO and told Dana my story. She told me they had received calls and knows that they have received a bad batch of parts and are working to figure what has happened to cause this. She said this has never happened before that the car runs for 2 minutes and shuts off and won't restart. She called me 2 weeks later and said it was the computer boards and they are now back to building the boxes and will send me a replacement when ready. Just wanted to let folks know if you have been having problems with your ignition. Just a heads up.
