moper
Yup.... 18ft pounds... and the holes should have been tapped when the valve job was done...
Here's to you... my own stock..
Thanks all. The guy at the machine shop got the snapped bolt out and I'm back in business. 18 lbs it is from now on, I even changed it in the book incase I forget down the road.
I forgot to mention and you might be interested but the Hughes hold down kit are studs rather than bolts. The hold downs themselves are made of billet steel.
Oh and a good buddy of mine 340sFastback recommend them.
Just for the knowledge of it ... what is the torque specs on a thermostat housing?
[/COLOR]
30 ft. lbs. on the thermostat housing bolts, but if aluminum intake, Heli Coil it first.
Fishy,
if you can find a carbide drill bit it should be able to drill though the tap. We did one today with a carbide end mill on a bridge port machine. Made drilling the tap very easy.
I've never figured out how to get a torque wrench into the four inside bolt on the RPM intake. A socket wont even fit with a u-joint on it.
LOL! I know, it scares the hell out of me too but sometimes it happens. :-DIt all seemed to go together well which makes me nervous.
I just cross tighten those bolts and snug them up. I never torque the intake but I do go back after it has been run for a while and snug them up again in a cross tightening sequence. They don't need to be real tight so don't go crazy.
That's the way I've always done it too and never had a problem. I don't think I've ever had an intake that I could get a torque wrench on the middle bolts.
Crow feet. They look like a open end of a box wrench with a super short end. That end has a square for the torque wrench.
Yeah I have them but I always wondered if they affect the torque reading since it effectively lengthens the wrench. I have a good beam type torque wrench I test torque wrenches with. Maybe I should try using a crows foot and see if it does affect the reading.
Good, good luck, enjoy the ride!
Fishy, it does, I used to have the formula for this, but it's effect is small and determined by the length of the crow feet and other variables.
Beileve it or not, I think it was part of the instructions to my Crafstmen torque wrench.
