When your right. Your right, but being right doesn't make it right.
I went via Schmauchers mounts for selffish reasons. I'll keep the better set IMO, a later year (Spool) K-frame for an earlier year Duster.
The swapping of K-frames was un-appealing, an alignment is needed when you swing everything over.
Since I was going to upgrade the braking system, the alignment needed was expected. But at the very least, I can move it around or drive it until I get to the brake swap.
For a $162 to the door and short work on the K frames motor pearch, I think it's win win for me.
