Heater Control
WarHammer
Active Member
Havelock, NC
Hello all. I picked up a dash for my 71 Duster and noticed that my heater control does not match the opening of the newly acquired dash. Can anyone assist with the proper assembly that should be used? Thanks.
I assume that you are dealing with a change from 72 to 73. Dash and bezel obviously don't match. You have a 73+ dash and your bezel is 72 and down. Heater box assemblies are different as well starting in 1973.
You bought the wrong dash frame for a 71. You have the correct plastic bezel but it will not work on that 73-76 dash frame. There could be something different with the glove box lock latch on the frame also depending on the year.
