Heater core re-cored? Or such thing as a universal one?
Johnny Mac
www.blueprintengines.com
FABO Vendor
OHIO
Hey all, My 78 B body (the powertour car I'm building) has an A/C heater box, and unfortunately that heater core is discontinued in the aftermarket. The firewall and box is COMPLETELY different than a non A/C car. So my 75 parts car is useless in this aspect. . I haven't successfully found a place that 're cores. And for anything north of $150...I would just buy one of the universal under dash heaters.
Any other ideas?? Appreciate it!!! Asked on the B site and got notta
Get all the aftermarket PN#s you can find for it, and do a PN search. Also check www partsvoice.com with the OEM PN.
Thanks, will see if I can pull a PN off it. I have lived in the aftermarket all my life, so I never even consider looking for an actual Chrysler # lol. Usually bc if someone has something NOS, it could be for a yugo and people will want $$$$ :p
It might be worth a try, go to the Mancini Racing site (all MOPAR) and see if they have one. If not give them a call and they might be able to send you to the right company. I needed one for my 68 barracuda with factory AIR they had it and it fit real good, can't hurt.
Bob
What model is that thing? A Charger?
The shell (firewall and heater box) is technically a 78 monaco 2 door. With A/C
I usually look up 78 Cordoba or charger, as some parts searches incorrectly pull the "Royal Monaco" which was a C body.
These two astronomically different animals are A/C and Non
I needed a discontinued one for an old Dodge truck. I got a heater core catalog (Murray I think) found one similar. I cut, repositioned one of the outlets and soldered it back on. If ya can or have a buddy that can weld aluminum, you have it made. Craig
SO what's the problem with converting it to non A/C?
I'm yanking the AC stuff. It's gone already. But the heater boxes, ducting, and firewall are completely different.
I suppose if I had a non AC dash and vents...But I don't.
To make all this that much more silly, the core doesn't leak, but looks rough.
So I hoped to replace it, use the AC box, and all would be well. It just wouldn't have A/C
So fill in the firewall holes and put somethin like this in it.
Car Universal Under dash Heater Heat Defroster Demister W/ Switch 12V 4 Ports | eBay
how bout a pic or three...with rough dims....
Late B had some similar stuff to F,M and J's.
Rock Auto shows to have 2 different ones for 78 cordoba non a/c ,1 is $47.79 the other is 67.79,,, the A/c shows out of stock. The photos you show , the tri-angle shape takes a blower which mounts from outside straight to heater box which has 4 studs, the other round hole takes a different blower motor that the heater box under dash is mounted , with front removed, you mount motor and bolt it inside ,then put heater box front on.
8x 6.76. 2 thick.
Thanks guys.
225 local to 're core. Lol....pass on that
I think we're going to make this work 73 charger with A/C. Same core dims. similar shape.
thank you all that helped!
i have owned some 10 or so Austin Mini Coopers, and here in Florida always had a overheating problem with those radiators small as heater cores. My "solution" was to go to NAPA or Oreilly and search/look in their books until i found the size/shape/outlet i wanted, and then plumbed that Heater Core into the stern of my mini's, running a 1/2in copper tubing back that-a-ways making me a 2nd radiator!! worked great. you might think about looking in NAPA or Oreilly's books (or possibly other manufactures also).
That's kind of what I did online. I found the 73 charger to look about the same, and it was close enough I made it work.
