..........Heater hose strainer..........."modern problems" LOL
67Dart273
Idaho
The "mini whale" (white Dakota project) already suffered from a mostly clogged heater core. This is something that I've NEVER experienced until this "modern stuff" came along. After changing the core in the green Dakota (which I sold) it's obvious that the tiny tube passages in these modern cores WILL PLUG with just a little junk
Changin the green Dak heater........tiny joke of a core, I put the "heavy duty" one NAPA listed back in, which was way thicker
So after backflushing the one in the "mini whale" project, and it may/ may not be totally clear, I intend to flush it AGAIN, and install this "Y" strainer which I bought off an ebay seller named "DudaDiesel" for about 12 bucks. The brass 5/8 barbs to 1/2" pipe I just now bought from HD for about 9 bucks
This will go in the pass side hose in place of the brass factory splice
I feel your pain . I just got my Dakota back from having the heater backflushed for the third time . I'm thinking its days are numbered . I would have done this myself but it is 9*F. outside . My better half has an important medical appointment this week . Think the Dak is headed for the happy hunting ground .
P.S. I don't understand what the device is for . Some sort of filter ? OTR rigs have coolant filters that go between the rad and engine . Some even have a built in drain to make servicing easier . Why aren't they in cars ?
As I eluded to in the original post, the heater core is not only TINY in these rigs, but the PASSAGES are proportionately tiny. I would say they are from 1/4---1/6 the size of the "old school" like might be found in our old A bodies and others. "What this means" is that it takes a TINY amount of trash, relatively speaking, to plug them. If you Google this, "I ain't alone" LMAO and neither is Dodge. It's a fairly widespread problem across the brand names
The reason I sold my 2001 F150 was heater core shot. Rockauto for $50. 10hrs shop labor to change it...dash, airbags forget it! Good truck 350,000 kms.
You try flushing it with something like motorcraft VC-1? That and a spin-on style filter like the ones they use on the 6.0 diesels might save you a lot of heartache in the future..
And here is another way car makers screw us. With the tremendous price increase of copper some smart *** penny pincher said we could save money by decreasing the size of the tubes in the heater core. Let the customer worry about the clogs.
They've deleted replicable fuel filters in a lot of modern examples too. There isn't supposed to be a significant amount of debris in these fluid systems. Good for 10 years anyway.
...and after the second or third time you flush it...it starts leaking.
Here's an opportunity for the aftermarket to make a "better than OEM" product.
...and another thing...why in the F don't then have an access panel in the sheet metal from the engine side of the core? That's been pissing me off since the very first one I had to deal with on a 60's car back in the 80's.
I'm seriously tempted to put in an aftermarket generic core.
45EC01_AS01
