Part number?rockauto.com has a replacement for this in stock $39. Slightly different configuration to mount, but looks like it would work.
Ok so based only on how most gates are designed... the pics look reverse of your description. Lever in line with the pipe is gate open ( although it doesn't travel to fully inline ). Lever perpendicular to the pipe is gate closed. Automotive engineers don't always follow those rules.Alright everybody. Got the valve I ordered from Amazon. Installed and everything seems to work! Will need to figure out a more permanent mounting configuration. It's basically just held there by the hose now.
The downside is that the vacuum line enters on the opposite side. Will actually get to make sure it is working with the heat on tomorrow morning.
First picture is heat off, second picture is heat on.
