O.K. this should be an easy one. 1969 Dodge Dart.Where does the ground wire from the heater motor go to? I know I can ground it to any metal, but I want to know where it's supposed to go. Thanks.
Thanks. That helps a lot. Also shows the cable location. Looking at the photo, see the tan wire thats not connected? That is the one I need to know where it goes.If you're still following this, why are the defrost outlets on the heater a different size than the dash vents?
On a 67 and 68 the ground wire is attached with a sheet metal screw behind the right kick panel. I'll guess 69 is the same.
Left defrost hose is a little larger to move more air farther away from the source. Clears left side of glass as fast or faster than the right side.
