Heavy Breather!
Thought I'd give an update. I installed the baffle on the other side and it seamed to help. I noticed when I took the valve cover off and I look on the underside with the breather installed, I saw daylight in the notches of the cover fill hole. The cheap paper gasket on the breather cap had broke off so oil could come out the through the sides. I install another breather with a hose to the air clean, we'll if that fixes the problem.
Thanks again for everyone's help!
