HEI All in one
Want a good four pin GM look foe a old Kem. A Mopar box or a four pin is just a signal amplifier the coil can use.
I just used a Mopar breakerless dist. with a GM 4 pin. As an experiment, I DID NOT USE a heat sink, but just mounted it to a "flat" spot on the firewall near the wiper motor. I also simply used the factory coil. Works just fine, hotter spark than the Mopar ECU. I think it was Greg, Trailbeast? who redid my poor diagram for this one. Notice the orientation of the distributor connector. It must be wired so, or the rotor phase will be "off"
I also threw one "into a box" for emergency and test ignition. So far I've "test fired" several engines with it. Just hook the alligator clips to power, ground, and connect the distro
Did not even install manifolds!!
Even test-fired a Magnum. Made a quicky crappy carb adapter for the beer keg manifold, jacked up the pan with bricks and threw an engine plate and flywheel on. Fired it right up!!
LMFAO Anybody figure out what this is?
The heat sink is overrated outside a distributor if you ask me.
hows that fit in an early A. Old distributor barely clears as is. I have a HEI (actually bosch module) all in one and have been looking for a year for just a stupid cap clip. Everyone sells the distributor, no one knows who makes it or where to get parts.
This guy uses one in his thread about the swap. Looks like a tight fit but it does fit. That's what got me looking at these in the first place. Though, I admit, the idea of putting one together from stock parts is looking better to me.
What did you do? I've got mine broke in but not sure the alternator is hooked up right. BTW I'm running a Magnum 408 with stock serpentine set up
I have serpentine as well.
and 1991 stock alt.
Check if your charging properly.
If not pm me.
I think you're better off remotely mounting the HEI module because it's easier to keep it cool and you can use an ordinary Mopar EI distributor. I have mine mounted on an aluminum bar with an HEI heatsink for added cooling. See HEI Ignition Upgrade.
Changing back from the import HEI to a full Mopar system because the module failed? Seriously? That's pretty laughable when this would have fixed it.
It wasn't the HEI module that failed, it was the pickup assembly.
Only you, Del. That's great, man. lol
Just as easily found. But hey, whatever floats your boat. Just run what you like.
Guys like you think they know it all. The distributor died a day before the big event I planned to drive to. I spent a couple of hours looking for a replacement pickup online and at the local parts store proved fruitless. Of course the distributor does not come with a parts list..... I stole a distributor out of my son's 340 and quickly rigged up the HEI module so the car would run and haven't got around to doing anything else as it runs great now.
I am going to a Holley Sniper EFI and so fixing it now is a waste of time as I am changing direction with the distributor. I still think the chinese distributor is a piece of junk and don't think it was worth anymore time to work on. To the trash pile it goes.
So maybe you ought to stick to more meaningful comments please.
BUICK ROADMASTER 1996 to 1996 V8-350ci 5.7L F/I Vin P
CADILLAC ESCALADE 1999 to 2000 V8-350ci 5.7L F/I Vin R
CADILLAC FLEETWOOD 1996 to 1996 V8-350ci 5.7L F/I Vin P
CHEVROLET ASTRO VAN 1996 to 2001 V6-262ci 4.3L F/I Vin W
CHEVROLET ASTRO VAN 2002 to 2003 V6-262ci 4.3L F/I Vin X
CHEVROLET BLAZER S10/T10 1996 to 2002 V6-262ci 4.3L F/I Vin W
CHEVROLET BLAZER S10/T10 2004 to 2005 V6-262ci 4.3L F/I Vin X
CHEVROLET CAMARO Z28 1996 to 1997 V8-350ci 5.7L F/I Vin P (Z28)
CHEVROLET CAPRICE 1996 to 1996 V8-265ci 4.3L F/I Vin W
CHEVROLET CAPRICE 1996 to 1996 V8-350ci 5.7L F/I Vin P
CHEVROLET CORVETTE LT1 1996 to 1996 V8-350ci 5.7L F/I Vin P
CHEVROLET CORVETTE LT4 1996 to 1996 V8-350ci 5.7L F/I Vin 5
CHEVROLET IMPALA SS 1996 to 1996 V8-350ci 5.7L F/I Vin P
CHEVROLET PICKUP C1500 1/2 TON 4x2 1996 to 1998 V6-262ci 4.3L F/I Vin W
CHEVROLET PICKUP C1500 1/2 TON 4x2 1996 to 1999 V8-305ci 5.0L F/I Vin M
CHEVROLET PICKUP C1500 1/2 TON 4x2 1996 to 1999 V8-350ci 5.7L F/I Vin R
CHEVROLET PICKUP C2500 3/4 TON 4x2 1996 to 1999 V8-305ci 5.0L F/I Vin M
CHEVROLET PICKUP C2500 3/4 TON 4x2 1996 to 2000 V8-350ci 5.7L CNG/FI Vin R
CHEVROLET PICKUP C2500 3/4 TON 4x2 1996 to 2000 V8-350ci 5.7L F/I Vin R
CHEVROLET PICKUP C2500 3/4 TON 4x2 1996 to 2000 V8-454ci 7.4L F/I Vin J
CHEVROLET PICKUP C3500 1 TON 4x2 1997 to 1999 V8-350ci 5.7L CNG/FI Vin R
CHEVROLET PICKUP C3500 1 TON 4x2 1996 to 2000 V8-350ci 5.7L F/I Vin R
CHEVROLET PICKUP C3500 1 TON 4x2 1996 to 2000 V8-454ci 7.4L F/I Vin J
CHEVROLET PICKUP K1500 1/2 TON 4x4 1996 to 1998 V6-262ci 4.3L F/I Vin W
CHEVROLET PICKUP K1500 1/2 TON 4x4 1996 to 1999 V8-305ci 5.0L F/I Vin M
CHEVROLET PICKUP K1500 1/2 TON 4x4 1996 to 1999 V8-350ci 5.7L F/I Vin R
CHEVROLET PICKUP K2500 3/4 TON 4x4 1996 to 2000 V8-350ci 5.7L CNG/FI Vin R
CHEVROLET PICKUP K2500 3/4 TON 4x4 1996 to 2000 V8-350ci 5.7L F/I Vin R
CHEVROLET PICKUP K2500 3/4 TON 4x4 1996 to 1996 V8-454ci 7.4L 4 BBL Vin J
CHEVROLET PICKUP K2500 3/4 TON 4x4 1997 to 2000 V8-454ci 7.4L F/I Vin J
CHEVROLET PICKUP K3500 1 TON 4x4 1996 to 2000 V8-350ci 5.7L F/I Vin R
CHEVROLET PICKUP K3500 1 TON 4x4 1996 to 2000 V8-454ci 7.4L F/I Vin J
CHEVROLET PICKUP S10/T10 1996 to 2002 V6-262ci 4.3L F/I Vin W
CHEVROLET PICKUP S10/T10 1996 to 2003 V6-262ci 4.3L F/I Vin X
CHEVROLET SILVERADO 1500 1999 to 2002 V6-262ci 4.3L F/I Vin W
CHEVROLET SILVERADO 1500 2003 to 2005 V6-262ci 4.3L F/I Vin X
CHEVROLET SILVERADO 1500 2002 to 2002 V6-262ci 4.3L FLEX/FI Vin X
CHEVROLET SUBURBAN C1500 1/2TON4x2 1996 to 1999 V8-350ci 5.7L F/I Vin R
CHEVROLET SUBURBAN C2500 3/4TON4x2 1996 to 1999 V8-350ci 5.7L F/I Vin R
CHEVROLET SUBURBAN C2500 3/4TON4x2 1996 to 1999 V8-454ci 7.4L F/I Vin J
CHEVROLET SUBURBAN K1500 1/2TON4x4 1996 to 1999 V8-350ci 5.7L F/I Vin R
CHEVROLET SUBURBAN K2500 3/4TON4x4 1996 to 1999 V8-350ci 5.7L F/I Vin R
CHEVROLET SUBURBAN K2500 3/4TON4x4 1996 to 1999 V8-454ci 7.4L F/I Vin J
CHEVROLET TAHOE 1996 to 2000 V8-350ci 5.7L F/I Vin R
CHEVROLET VAN G1500 1/2 TON 1998 to 1998 V6-262ci 4.3L F/I Vin W
CHEVROLET VAN G1500 1/2TON EXPRESS 1996 to 2002 V6-262ci 4.3L F/I Vin W
CHEVROLET VAN G1500 1/2TON EXPRESS 2003 to 2007 V6-262ci 4.3L F/I Vin X
CHEVROLET VAN G1500 1/2TON EXPRESS 1996 to 2002 V8-305ci 5.0L F/I Vin M
CHEVROLET VAN G1500 1/2TON EXPRESS 1996 to 2002 V8-350ci 5.7L F/I Vin R
CHEVROLET VAN G20 3/4 TON 1997 to 1997 V6-262ci 4.3L F/I Vin W
CHEVROLET VAN G20 3/4 TON 1997 to 1997 V8-305ci 5.0L F/I Vin M
CHEVROLET VAN G2500 3/4 TON 1998 to 1998 V8-305ci 5.0L F/I Vin M
CHEVROLET VAN G2500 3/4TON EXPRESS 1996 to 2002 V6-262ci 4.3L F/I Vin W
CHEVROLET VAN G2500 3/4TON EXPRESS 2003 to 2005 V6-262ci 4.3L F/I Vin X
CHEVROLET VAN G2500 3/4TON EXPRESS 1996 to 2002 V8-305ci 5.0L F/I Vin M
CHEVROLET VAN G2500 3/4TON EXPRESS 2002 to 2002 V8-350ci 5.7L BIFUEL/FI Vin R
CHEVROLET VAN G2500 3/4TON EXPRESS 2001 to 2002 V8-350ci 5.7L CNG/FI Vin R
CHEVROLET VAN G2500 3/4TON EXPRESS 1996 to 2002 V8-350ci 5.7L F/I Vin R
CHEVROLET VAN G2500 3/4TON EXPRESS 1997 to 1999 V8-395ci 6.5L Diesel Turbo Vin F
CHEVROLET VAN G30 1 TON 1996 to 1996 V8-454ci 7.4L F/I Vin N
CHEVROLET VAN G3500 1 TON EXPRESS 2002 to 2002 V8-350ci 5.7L BIFUEL/FI Vin R
CHEVROLET VAN G3500 1 TON EXPRESS 2001 to 2002 V8-350ci 5.7L CNG/FI Vin R
CHEVROLET VAN G3500 1 TON EXPRESS 1996 to 2002 V8-350ci 5.7L F/I Vin R
CHEVROLET VAN G3500 1 TON EXPRESS 1997 to 2000 V8-454ci 7.4L F/I Vin J
CHEVROLET VAN P30 1996 to 1999 V6-262ci 4.3L F/I Vin W
CHEVROLET VAN P30 1996 to 1999 V8-350ci 5.7L F/I Vin R
CHEVROLET VAN P30 1997 to 1997 V8-395ci 6.5L Diesel Turbo Vin F
CHEVROLET VAN P30 1997 to 1997 V8-395ci 6.5L Diesel Vin Y
CHEVROLET VAN P30 1996 to 1999 V8-454ci 7.4L F/I Vin J
GMC JIMMY S15/T15 1996 to 2001 V6-262ci 4.3L F/I Vin W
GMC PICKUP C1500 1/2 TON 4x2 1996 to 1998 V6-262ci 4.3L F/I Vin W
GMC PICKUP C1500 1/2 TON 4x2 1996 to 1999 V8-305ci 5.0L F/I Vin M
GMC PICKUP C1500 1/2 TON 4x2 1996 to 1999 V8-350ci 5.7L F/I Vin R
GMC PICKUP C2500 3/4 TON 4x2 1996 to 1998 V8-305ci 5.0L F/I Vin M
GMC PICKUP C2500 3/4 TON 4x2 1996 to 2000 V8-350ci 5.7L CNG/FI Vin R
GMC PICKUP C2500 3/4 TON 4x2 1996 to 2000 V8-350ci 5.7L F/I Vin R
GMC PICKUP C2500 3/4 TON 4x2 1996 to 1996 V8-395ci 6.5L Diesel Turbo Vin F
GMC PICKUP C2500 3/4 TON 4x2 1996 to 2000 V8-454ci 7.4L F/I Vin J
GMC PICKUP C3500 1 TON 4x2 1997 to 1999 V8-350ci 5.7L CNG/FI Vin R
GMC PICKUP C3500 1 TON 4x2 1996 to 2000 V8-350ci 5.7L F/I Vin R
GMC PICKUP C3500 1 TON 4x2 1996 to 2000 V8-454ci 7.4L F/I Vin J
GMC PICKUP K1500 1/2 TON 4x4 1996 to 1998 V6-262ci 4.3L F/I Vin W
GMC PICKUP K1500 1/2 TON 4x4 1996 to 1999 V8-305ci 5.0L F/I Vin M
GMC PICKUP K1500 1/2 TON 4x4 1996 to 1999 V8-350ci 5.7L F/I Vin R
GMC PICKUP K2500 3/4 TON 4x4 1996 to 2000 V8-350ci 5.7L CNG/FI Vin R
GMC PICKUP K2500 3/4 TON 4x4 1996 to 2000 V8-350ci 5.7L F/I Vin R
GMC PICKUP K2500 3/4 TON 4x4 1996 to 2000 V8-454ci 7.4L F/I Vin J
GMC PICKUP K3500 1 TON 4x4 1996 to 2000 V8-350ci 5.7L F/I Vin R
GMC PICKUP K3500 1 TON 4x4 1996 to 2000 V8-454ci 7.4L F/I Vin J
GMC PICKUP SONOMA 1996 to 2002 V6-262ci 4.3L F/I Vin W
GMC PICKUP SONOMA 1996 to 2003 V6-262ci 4.3L F/I Vin X
GMC SAFARI VAN 1996 to 2001 V6-262ci 4.3L F/I Vin W
GMC SAFARI VAN 2002 to 2003 V6-262ci 4.3L F/I Vin X
GMC SIERRA 1500 1999 to 2002 V6-262ci 4.3L F/I Vin W
GMC SIERRA 1500 2002 to 2005 V6-262ci 4.3L F/I Vin X
GMC SUBURBAN C1500 1/2TON4x2 1996 to 1999 V8-350ci 5.7L F/I Vin R
GMC SUBURBAN C2500 3/4TON4x2 1996 to 1999 V8-350ci 5.7L F/I Vin R
GMC SUBURBAN C2500 3/4TON4x2 1996 to 1999 V8-454ci 7.4L F/I Vin J
GMC SUBURBAN K1500 1/2TON4x4 1996 to 1999 V8-350ci 5.7L F/I Vin R
GMC SUBURBAN K2500 3/4TON4x4 1996 to 1999 V8-350ci 5.7L F/I Vin R
GMC SUBURBAN K2500 3/4TON4x4 1996 to 1999 V8-454ci 7.4L F/I Vin J
GMC VAN G1500 1/2 TON 1998 to 1998 V8-350ci 5.7L F/I Vin R
GMC VAN G1500 1/2 TON SAVANA 1998 to 2002 V6-262ci 4.3L F/I Vin W
GMC VAN G1500 1/2 TON SAVANA 1997 to 1997 V6-262ci 4.3L F/I Vin W (SAVANA)
GMC VAN G1500 1/2 TON SAVANA 1996 to 1996 V6-262ci 4.3L F/I Vin W (SAVANNA)
GMC VAN G1500 1/2 TON SAVANA 2003 to 2007 V6-262ci 4.3L F/I Vin X
GMC VAN G1500 1/2 TON SAVANA 1998 to 2002 V8-305ci 5.0L F/I Vin M
GMC VAN G1500 1/2 TON SAVANA 1996 to 1997 V8-305ci 5.0L F/I Vin M (SAVANA)
GMC VAN G1500 1/2 TON SAVANA 1999 to 2002 V8-350ci 5.7L F/I Vin R
GMC VAN G1500 1/2 TON SAVANA 1996 to 1997 V8-350ci 5.7L F/I Vin R (SAVANA)
GMC VAN G2500 3/4 TON 1998 to 1998 V6-262ci 4.3L F/I Vin W
GMC VAN G2500 3/4 TON 1997 to 1997 V6-262ci 4.3L F/I Vin W (SAVANA)
GMC VAN G2500 3/4 TON 1998 to 1998 V8-305ci 5.0L F/I Vin M
GMC VAN G2500 3/4 TON SAVANA 1999 to 2002 V6-262ci 4.3L F/I Vin W
GMC VAN G2500 3/4 TON SAVANA 1996 to 1996 V6-262ci 4.3L F/I Vin W (SAVANA)
GMC VAN G2500 3/4 TON SAVANA 2003 to 2005 V6-262ci 4.3L F/I Vin X
GMC VAN G2500 3/4 TON SAVANA 1999 to 2002 V8-305ci 5.0L F/I Vin M
GMC VAN G2500 3/4 TON SAVANA 1996 to 1997 V8-305ci 5.0L F/I Vin M (SAVANA)
GMC VAN G2500 3/4 TON SAVANA 2001 to 2002 V8-350ci 5.7L BIFUEL/FI Vin R
GMC VAN G2500 3/4 TON SAVANA 2001 to 2002 V8-350ci 5.7L CNG/FI Vin R
GMC VAN G2500 3/4 TON SAVANA 1998 to 2002 V8-350ci 5.7L F/I Vin R
GMC VAN G2500 3/4 TON SAVANA 1996 to 1997 V8-350ci 5.7L F/I Vin R (SAVANA)
GMC VAN G2500 3/4 TON SAVANA 1998 to 1998 V8-395ci 6.5L Diesel Turbo Vin F
GMC VAN G2500 3/4 TON SAVANA 1997 to 1997 V8-395ci 6.5L Diesel Turbo Vin F (SAVANA)
GMC VAN G3500 1 TON 1999 to 1999 V8-454ci 7.4L F/I Vin J
GMC VAN G3500 1 TON SAVANA 1997 to 1997 V6-262ci 4.3L F/I Vin W (SAVANA)
GMC VAN G3500 1 TON SAVANA 2001 to 2002 V8-350ci 5.7L BIFUEL/FI Vin R
GMC VAN G3500 1 TON SAVANA 2001 to 2002 V8-350ci 5.7L CNG/FI Vin R
GMC VAN G3500 1 TON SAVANA 1996 to 1996 V8-350ci 5.7L F/I Vin K (SAVANA)
GMC VAN G3500 1 TON SAVANA 1998 to 2002 V8-350ci 5.7L F/I Vin R
GMC VAN G3500 1 TON SAVANA 1997 to 1997 V8-350ci 5.7L F/I Vin R (SAVANA)
GMC VAN G3500 1 TON SAVANA 1998 to 2000 V8-454ci 7.4L F/I Vin J
GMC VAN G3500 1 TON SAVANA 1997 to 1997 V8-454ci 7.4L F/I Vin J (SAVANA)
GMC VAN G3500 1 TON SAVANA 1996 to 1996 V8-454ci 7.4L F/I Vin N (SAVANA)
GMC VAN P35/P3500 1996 to 1999 V6-262ci 4.3L F/I Vin W
GMC VAN P35/P3500 1996 to 1999 V8-350ci 5.7L F/I Vin R
GMC VAN P35/P3500 1997 to 1999 V8-454ci 7.4L F/I Vin J
GMC VAN P35/P3500 1996 to 1996 V8-454ci 7.4L F/I Vin N
GMC YUKON 1996 to 2000 V8-350ci 5.7L F/I Vin R
ISUZU HOMBRE 1997 to 1997 V6-262ci 4.3L F/I Vin X
ISUZU HOMBRE 1998 to 2000 V6-4294cc 4.3L F/I Vin X
OLDSMOBILE BRAVADA 1996 to 2001 V6-262ci 4.3L F/I Vin W
PONTIAC FIREBIRD 1997 to 1997 V8-350ci 5.7L F/I Vin P
PONTIAC FIREBIRD FORMULA 1996 to 1996 V8-350ci 5.7L
I didn't use the module that came with the coil, I bought a $10 4 pin module and used appliance grade spade connectors. Since I ordered everything new, I wouldn't have to search for a harness. I mounted mine on the passenger side firewall since it was much less crowded. I took the part of the factory harness that attached to the distributor and attached them to the module.
Thanks for the info. Always good to see others examples.
Also important to note that uoy will need to get the longest plug wire that will connect to the coil, to modify one end for the factory distributor terminal. ( I found this out the hard way and had to buy a cheap set of LS plug wires to rob the terminal off of and add to a universal wire to make it work)
Also important to proof read fitment lists from Google / ebay before posting! I'm pretty sure they didn't come on Diesel vans lol
If I may be so bold as to suggest ? the GM HEI dizzys are too big to fit in a-bodies . Trucks are o.k. Petronix Ignitor II is my suggestion along with their coil . The factory dizzy is o.k. but most are 40+ years old and worn out . the bushings are worn and the shaft has way too much end play. The PETRONIX eliminates the ballast resistor and has adjustments inside to limit advance . The cap and rotor are off the shelf GM parts available everywhere . Vacuum advance is adjustable too .
Use the small distributor cap HEI...it fits...it works...its cheap...so cheap buy two ...and have spare parts...LOL
Dumb question, will I need to get a different alternator for this swap or will the existing one on the /6 work? Not sure about the wiring etc.
