player1up
I converted my /6 to a hei system a few months back and I've been having this issue with missfire when the engine is hot or more like something is getting hot and cutting out. I've tried 5 different HEI modules 4-pin, 7-pin, and an 8-pin accel, and they all do the same thing when the temp under the hood gets too hot (1/3 up the gauge), no power, sputtering, pops thru the carb. I have both systems in the car at the moment (only one hooked up at a time) so I can test it. Does this sound like a bum coil? as all of the modules have the same symptoms....and if it is the coil how do I get the correct coil (resistance) for the module or does it matter? The current coil is a solid plastic type 12v, .9 ohms primary and 8.5kohms secondary.
My next course of action is to bust out the heat gun and see if I can make it happen while the engine is cold...
