helicoil choice
grjammer
PA
Didn't know where else to ask this, but what size and type of helicoil would be best for trans bolts for an A833 into aluminum bell? should it be wire inserts?
Generally you look up a heli coil size by the specs of the original bolt.
yes, just go to a "fasten all" type store with the original bolt, and they will set you up with the correct drill bit, tap and insert. I just did this myself.
that's what I probably will do. have a Fastenal a block away. Thanks for input
