What is the length of the original pushrod?
And from that pix, they are about 'half a ball' different in length, which is what the listed variation is in the early vs. late ones for '92: 0.15-0.16" difference.
As above, there are variables that are unknown (to us). What head gaskets did you use? Out of a standard Felpro kit?It's more about past services on the head, gasket thickness, valves stem height increases with valve jobs and not all will cut the stem height back to factory tolerance.
Heads milled
Valves faced/ground
Seats ground
Gasket maybe thinner
All that equates to... is the necessity of a shorter push rod.
Well, You'd better give the valve seals a real careful inspection before continuing, I don't know how close that clearance was but it bears a good lookie-see.Hahaha. I did lol. But took the push rods out and saw they are bigger then the old ones
I used the rocker arms from the 308 heads that were cracked. They were the same as the 302 ones. But i used them cause they were fineLook at the top of your rocker arms. The roller cam motor rockers don't have oil holes in the pushrod sockets, the sockets oiled through the pushrod.
Interesting.. whose book? Melling shows MPR-381 with a length of 6.707". Measured differently? No ready info on whether it has the holes....Edit: I looked up the pushrods....... 6.777oal, with oil holes.
This book shows them used from 89-92.
would love to hear how this motor runs out when you get it all sorted out!!Thats interesting. I didnt know that. Well i got the new push rods in. I got the drivers side done and started on the passengers side. With all my damn luck i pulled out the new pushrods and one was wrong. Someone must of put it in during the packaging from rockauto. I just went to a local dealer and got one. I adjusted the timing and did a compression test and got around 120 on all cylinders. Truck fired up fine. I just need to drive it around and work out the bugs. Thanks everyone for the help
Oh yeah heres a pic of the wrong pushrod
Rockauto sucks! Most of my orders from them have been screwed up. High shipping charges, crappy returns. I ordered a "matched" set of A/C belts for my Ramcharger last month and they sent me 2 different brands of belts that were so far off from being a matched set. Would have cost me more to ship them back, than what it was worth.Just a tiny bit too long so you never noticed packing them up... great customer service at rockauto.
Roger.. ought to be answered by the OP, to be sure.Oil holes in them or not?
Cool , BUT fact still remains: Why were 6+ original pushrods bent when you pulled the manifold & 2/ why were there valve marks on the dished piston tops, when you pulled the cracked heads ?? (Unless I read wrong earlier) Did someone prior miss a shift big time ?? - valves kissing pistons .Its a sweet truck i picked up for 300 bucks. 92 d250, 3/4 ton. Needs a ac compressor but its all there, interior is really nice, body is really nice. Jas a goose neck hitch in the back and a regular hitch, and trailer brake. Push bar in the front, front visor and running bars. Also has a deep tranny pan. The guy was going to scrap it cause he couldnt get it running right.
