I found the paper with the dimensions on. with the rear housing centered in the wheel well to the very front of the back half cross bar is 33.5" from the center of the housing. all the vertical measurements are from ground level I have, so you can set it up with these plus what even height off floor the hotrod sits. the front cross bar of the back half is 8", the center of the bottom hole for the bottom link bar is 7 .125", the center of the housing is 16", the rear of the back half is 23"-27". for starters the link bar angle for the top one is at 17* and the bottom one is at 7*. you can buy or make the shock set-up bar the is 14" c-c. I can't post a pic because the puter with the printer is on the fritz.
