bvt69dart Technically Challenged! Joined Oct 6, 2008 Messages 913 Reaction score 196 Location Littleton, Colorado May 22, 2009 #1 Where would I find the manufacture date on my '69 Dart?
B beawulf Well-Known Member Joined Aug 7, 2008 Messages 53 Reaction score 0 May 22, 2009 #2 As far as I know it's on the VIN number or fender tag
bvt69dart Technically Challenged! Joined Oct 6, 2008 Messages 913 Reaction score 196 Location Littleton, Colorado May 22, 2009 #3 Thanks for the reply. I tried the VIN decoder with no luck. Any other suggestions?
LS-300 Well-Known Member Joined Nov 19, 2008 Messages 671 Reaction score 104 Location Ohio May 22, 2009 #4 I believe it is part of the fender tag. You can go here to get it decoded: http://www.stockmopar.com/mopar-fender-tag-decoder.php
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,930 Location 92201 May 22, 2009 #5 Need Fender tag or broadcast sheet. Fender tag, second row from the bottom, second set of digits from the right side. It's a 3 digit code, the set to the right should be six digits.
bvt69dart Technically Challenged! Joined Oct 6, 2008 Messages 913 Reaction score 196 Location Littleton, Colorado May 22, 2009 #6 Thanks guys. I knew you would come through!
