kiss
My 71 Dart has an LA 360 (mostly stock) going in. I have a Mopar 22" radiator (I think that's the size, it's the full length radiator, not the small one) that was re-cored to 3 cores. The lower radiator has a passenger side port. The thing is, is the water pump lower outlet is bigger than the port on the radiator. I need a solution for this. Is there a hose with 1 end flared more that will fit this configuration? I'd like to avoid splicing hoses together if possible.
Thanks!
Thanks!
