valianator
Active Member
I have a set of B-body 10" drums swapped onto my 65 Valiant (with 73-76 UCAs).
I started hearing a god-awful racket from my left front wheel, took it apart to find the outer bearing race spinning loose in the "wallered out" hub casting. I just put new bearings in few months back... don't know what, if anything, I screwed up. #-o
So I'm needin' a hub to get rollin' again.
My brakes came from a 66 B body.
A quick check shows all drum brake 62-72 B bodies and 65-71 C bodies using the same front wheel bearings so the hubs *should* interchange.
I just need a hub, not a drum (my drums are nearly new).
I'll even send my old one back to you if you need it to keep a parts car roll-able!
HELP!!
Thanks.
HELP!!
Thanks.
