My best guess is from left to right number 2 is the 1-2 A body shift rod and number 3 is the 3-4 A body shift rod. You can tell those by the way the adjuster end is bent to make the rods clear the transmission cross member mount (whatever the technical name is for the frame member the crossmember bolts to) as they have to go up to miss it.
The other ones I have no clue.
