69MOPE
Even if you order the correct non shouldered bolts the part number changes to the shouldered ones with instructions to open up the holes in the carrier. I used a wooden dowl with 40 grit and honed them just enough for the shoulder to fit thru snugly. Note: Make SURE that nothing is between the case and ring gear, even a .005" piece of dirt will cause problems. Also, do NOT pull the ring gear down with the bolts.
